Watts has announced its “Fast Track to Labor Savings” eLearning campaign with dozens of bite-sized modules on Watts Works Online (many available in Spanish and French), d...
Taco Comfort Solutions® has expanded its family of easy-to-use, ECM high-efficiency circulators with the addition of the 0034e® and 0034ePlus® models. With a maximum of 34 feet of head and 50 GPM, the new circulators offer up to 85 percent energy savings over a conventional circulator.
The 0034e and 0034ePlus circulators are available with cast iron or NSF/ANSI 61 & 372 certified stainless steel volutes, so they are ideal for closed-loop hydronic heating systems as well as domestic hot water recirculation systems. Both circulators also offer a convenient, rotatable control box cover for a professional look, no matter the orientation of the installed circulator.
The 0034e features an easy-to-use dial with five operating modes, including constant pressure, fixed speed, Taco’s exclusive TacoADAPTTM self-adjusting proportional pressure, and 0-10V capability. The 0034ePlus adds proportional pressure and more constant pressure settings as well as a digital display with real-time feedback, including watts, GPM, feet of head, and RPM. Both circulators are dual-voltage 115V/230V.
The new circulators come with exclusive features that make Taco’s ECM high-efficiency circulators so easy to use, including SureStart® automatic unblocking and air purging, BIO Barrier® black iron oxide protection, dual electrical knockouts, and recessed flange nut-grabbers.
For more information, visit www.TacoComfort.com
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, will highlight its latest commercial offerings at the Mechanical...
Rinnai’s RCW Series commercial boilers are delivering sustained, high efficiency water heating performance at 2150 Condos in Toronto, marking the first installation of th...
