Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
With the addition of eLink, Taco Comfort Solutions® avails rapid, mobile access to all product information.
eLink uses NFC tags installed on Taco products to provide users with all relevant information by linking to a digital document library of the most up-to-date documentation and information for that specific piece of equipment.
By simply tapping an Android or Apple device to the eLink NFC tag on the Taco product, users quickly access information such as technical specs, repair parts, tech support contact, rep information, catalog sheets, CAD/REVIT files and more.
A variety of Taco pumps are now equipped with eLink tags, as well as most thermal fabricated products, like heat exchangers, tanks, and large air separators.
For more information, please visit www.TacoComfort.com.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
