Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Calefactio pioneers with The ONE
Calefactio Solutions is proud to present The ONE(TM) expansion tank, a device combining three functions that is unique and exclusive to Calefactio and allows important time, money and space savings while minimizing the risks of leaks.
The ONE(TM) expansion tank has won the New Products competition in the heating and/or air conditioning hydronic components category at MCEE, Montreal’s biennial plumbing show. It combines three essential functions in plumbing: an expansion tank, air & dirt separation and deaeration, resulting in important savings.
Ingenious design
The ONE is designed to be durable, easy to install and maintain. Its EPDM bladder protects the shell from any and all contact with heating fluid that would cause corrosion and eventually threaten its proper functioning. Its bladder is replaceable and is equipped with a drain valve, for easy maintenance. The high efficiency air & dirt separator quickly reduce fluid velocity because of its large diameter and slots. The coalescent media offers a vast contact area, facilitating air and dirt particles to hang. The automatic air vent has an oversized chamber not only allowing greater amount of air to be liberated, but also protecting the valve from any and all contact with the heating fluid because of the important distance between the valve itself and the liquid level.
The ONE(TM) is available in Canada and United States. It is available in 2.1 and 4.8 gallons versions and is unique and exclusive to Calefactio. For more information, please see our local agents page.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
