Targeted for specific U.S. regional distribution partners, Uponor is launching TotalFit™ — the professional-grade, engineered polymer (EP), push-to-connect fitting solution that provides greater value for residential projects with the same versatility and speed as brass push-to-connect fittings.
Designed for use with PEX, PE-RT, CPVC, and copper piping systems, TotalFit is ideal for service repair, maintenance, remodels, and retrofits for potable hot-water and cold-water distribution piping systems in single-family homes, townhomes, apartments, and condominiums.
“Uponor has a strong leadership position in residential plumbing with AquaPEX® pipe and the ProPEX® fitting system,” says Aaron Stotko, director, Segment Marketing, at Uponor. “Now, with TotalFit, we are expanding into the plumbing repair, maintenance, and renovation segments with a high-quality, reliable fitting solution from a brand professionals trust.”
