The Improved Webster Type "R" System of Steam Heating is a service bulletin from Warren Webster and Company (The Pioneers of Vacuum Steam Heating), established in 1888.
Amstan Wet Heat and Cooling Products (1957) - Part 3
Here is a catalog from Amstan (American Standard), published in 1957, that features their wet heat and cooling products. This document is divided into 5 parts. Many of the products you'll find here are still in the field.
Thanks to John Mills for sharing and scanning this catalog. And thanks to Alex Marx for his help with the file conversions.
Comments by Vanilla
The Improved Webster Type "R" System of Steam Heating - Service Bulletin (1932)
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
H.B. Smith Company Oil Fired Cast Iron Hot Water Boilers (1972)
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
