This document contains the manufacturer's instructions for the HB Smith Series M450L Mills Water-Tube Boiler for automatic firing with oil or gas (Steam, Vapor, or Water ...
Beacon Boiler Reference Book, Boilers Made Prior to 1959, Part 4
This is an excerpt of the Beacon Boiler Reference Book, Sixth Edition and includes ratings for boilers made prior to 1959. This section contains pages 65 through 86 and includes ratings for these manufacturers: Crane Co., Crocker Htg. Eqpt. Co., Crotty Mfg.Co., Crown Home Equipment, Cruikshank Utilities, Co., V.M., Davis Co., John, Davis Engineering Corp., De-Lon Corp., Delco Appliance Div., Delta Heating Corp., Deringer Boiler Co., De Soto Oil Burner Corp., Dewey Shepard Boiler Co., Diesel Oil Burner Corp. of N.Y., Dodge,August W., Dowdeswell Co., Albert J., Drill Mfg., Co., Dunkirk Radiator Corp., Eastern Boiler Co., Eastern Foundry Co., Eastern Oil, Inc., Eckhart Mfg. Co., Edwards Engineering Corp., Electric Furnace-Man,Inc., Electrol Burner Mfg. Co., Erie City Iron Works, Esso Standard OilCo., Ettinger Co., J.M., Farrar & Trefts, Inc., Federal Boiler Co.,Federal Radiator Co., Fitzgibbons Boiler Co., Fluid Heat Div., and ForanBoiler Co.
This document contains the jacket assembly instructions for the HB Smith Series 45 Mills Boiler (circa 1979).
This document contains the combustion chamber assembly instructions for the HB Smith Series 45 Mills Water-Tube Boiler for automatic firing with oil or gas (Steam, Vapor,...
