HB Smith Series 45 Mills Boiler Jacket Assembly Instructions (1979)
This document contains the jacket assembly instructions for the HB Smith Series 45 Mills Boiler (circa 1979).
This document contains the manufacturer's instructions for the HB Smith Series M450L Mills Water-Tube Boiler for automatic firing with oil or gas (Steam, Vapor, or Water Heating). The document is dated July 1980.
This document contains the combustion chamber assembly instructions for the HB Smith Series 45 Mills Water-Tube Boiler for automatic firing with oil or gas (Steam, Vapor,...
This HB Smith catalog features the Mills M450L Oil- or Gas-Fired Cast Iron Boiler.
