This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Beacon Boiler Reference Book, Boilers Made Prior to 1959, Part 7
This is an excerpt of the Beacon Boiler Reference Book, Sixth Edition and includes ratings for boilers made prior to 1959. This section contains pages 128 through 146 and includes ratings for these manufacturers: Lebanon Boiler & Furnace Co., Lehigh ValleyService Co., Little Burner Co., H.C., Loline Steel Boiler Co., Lookout Boiler & Mfg. Co., Lord & Burnham, Ludlow Welding Co., LynnProducts Co., Macrae, Inc., Magee Furnace Co., Manville Boiler Co., Marietta Metal Products Corp., McAlister Boiler Works D.J., McIntyre Eng. Co., McLain Co. J.H., Michigan Tank & Heater Co., Miller Co., Molby Boiler Co., Monitor Bi-Loop Radiator Co., Montgomery Ward Co., Morheat Corp., Morrison & Co. Alexander, Motor Wheel Corp., MottIron Works J. L., Mt. Hawley Mfg. Co., Mueller Climatrol, Mustee HeaterCo., Nable Engine & Boiler Co., Nason Mfg. Co., National Fuel Convervation Co., National Prouducts Corp., and National Steel Construction Co.
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
