This document contains the manufacturer's instructions for the HB Smith Series M450L Mills Water-Tube Boiler for automatic firing with oil or gas (Steam, Vapor, or Water ...
Cyclopedia of Engineering (1910)
Published in 1910, the Cyclopedia of Engineering is a general reference work on steam boilers, pumps, engines, and turbines, gas and oil engines, automobiles, marine and locomotive work, heating and ventilating, compressed air, refrigeration, dynamos motors, electric wiring, electric lighting, elevators, etc. To access this book online, click here.
Comments by Vanilla
HB Smith Series M40L Mills Water-Tube Boiler (1980)
HB Smith Series 45 Mills Boiler Jacket Assembly Instructions (1979)
This document contains the jacket assembly instructions for the HB Smith Series 45 Mills Boiler (circa 1979).
HB Smith Series 45 Mills Water-Tube Boiler (1980)
This document contains the combustion chamber assembly instructions for the HB Smith Series 45 Mills Water-Tube Boiler for automatic firing with oil or gas (Steam, Vapor,...
