Designing Simplified for Taco Venturi Systems
Download pdf (798 KB)
This Designing Simplified for Taco Venturi Systems Using Radiators, Convectors, and Baseboard document contains very easy-to-follow instructions on how to size Taco Venturi tees. It was published in 1949.
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Published on 01/12/2026 11:38 AM
Posted in Heating Museum
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
Published on 03/07/2025 2:09 PM
