Emissive Tests of Paints for Decreasing or Increasing Heat Radiation from Surfaces
Download pdf (1.5 MB)
This document, published in 1924 by the Department of Commerce Bureau of Standards, contains information about Emissive Tests of Paints for Decreasing or Increasing Heat Radiation from Surfaces.
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Published on 01/12/2026 11:38 AM
Posted in Heating Museum
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
Published on 03/07/2025 2:09 PM
