H. A. Thrush & Company Catalog
Download pdf (327 KB)
Here's a look at the H. A. Thrush & Company product offering in 1946 for hot-water heating flow control valves, water circulators, pressure reducing valves, relief valves, dual control units, Thrush water heaters, and iron supply tees.
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Published on 01/12/2026 11:38 AM
Posted in Heating Museum
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
Published on 03/07/2025 2:09 PM
