The Improved Webster Type "R" System of Steam Heating is a service bulletin from Warren Webster and Company (The Pioneers of Vacuum Steam Heating), established in 1888.
H.B. Smith Company Oil Fired Cast Iron Hot Water Boilers (1972)
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is estimated to be from around 1972.
Comments by Vanilla
The Improved Webster Type "R" System of Steam Heating - Service Bulletin (1932)
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
