The Improved Webster Type "R" System of Steam Heating is a service bulletin from Warren Webster and Company (The Pioneers of Vacuum Steam Heating), established in 1888.
Hoffman Specialty Co. Heating System Information (1926)
This document is from the sales department at the Hoffman Specialty Co. in 1926. It showcases Hoffman Valves and Controlled Heat Equipment with cutaway diagrams of how the Hoffman No. 2 Vacuum Valve operates. There is also information on how to "vacuum-ize" a one-pipe steam system, the No. 7 Hoffman Adjustable Modulating Valve, Nos. 8 and 9 Hoffman Return Line Valves, the Hoffman Blast Trap, the Hoffman Ther-Kompo Gage, and the Hoffman Differential Loop. And there are diagrams outlining the typical installations of Hoffman "Controlled Heat" Equipment.
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
