How to Properly Design and Install The Honeywell System of Hot Water Heating
Download pdf (4.8 MB)
This book from The Honeywell Heating Specialty Co., issued around 1910, contains complete instructions for the system that changed the way the Dead Men did hot-water heating. This turn-of-the-century system delivered high-temperature gravity hot water heat, without the need for a closed compression tank. It was simplicity itself!
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Published on 01/12/2026 11:38 AM
Posted in Heating Museum
