This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Vento Cast Iron Heaters
This is an excerpt from The Ideal Fitter, which the American Radiator Company published yearly back in the day. It features the Vento Cast Iron Heater. It reads, "Just as American Peerless Radiators have become the standard for direct radiator heating, so also has the Vento Cast Iron Hot Blast Heater become the standard of merit for blower and ventilation systems."
Comments by Vanilla
O-E Vapor System Manual
H.B. Smith Company Oil Fired Cast Iron Hot Water Boilers (1972)
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
