Taco has introduced new, compact HS Series Horizontal Split Case Pumps, which take up 50% less floor space while offering the same superior hydraulic performance. Precisi...
Armstrong Fluid Technology has unveiled a new high performance Pressurizing Pump for the Latin American residential market that is designed to increase hydraulic pressure in homes that have dishwashers, high-flow showerheads, water heaters and other high-demand equipment.
Featuring low power consumption and a flow sensor that allows automatic activation, the new Armstrong Pressurizing Pump can supply a home with 1 to 5 bathrooms. It can be installed at the outlet of a water tank or before any supply or derivation to service.
Adaptable to both cold and hot water up to 90°C, the new pump is ideal for instantaneous heaters. It can also be used for ventilation, heating and air conditioning circulation.
The pump activates automatically when a tap is opened and turns off when the tap is closed.
Navien, a leading manufacturer of high-efficiency comfort solutions, has announced the launch of its new NAA Series air conditioner, further strengthening the company’s r...
Merino Energy, a San Francisco-based climate hardware company built to make buying and installing a heat pump as efficient as the technology itself, today emerged from st...
