Watts has announced its “Fast Track to Labor Savings” eLearning campaign with dozens of bite-sized modules on Watts Works Online (many available in Spanish and French), d...
The industry's first self-sensing, variable speed end suction pumps are now available from Taco.
The pumps, with integrated VFDs, permit fast, accurate balancing. They help to reduce balancing contractor costs, eliminate expensive wiring and the need for external sensors.
New SCI close-coupled end suction pumps, and SFI frame-mounted end suction pumps provide superior reliability and ease in installation for heating, air conditioning, pressure boosting, cooling water transfer and water supply applications. All meet the latest standards for hydraulic performance and dimensional characteristics for quiet, dependable performance.
Pump features include:
SFI frame-mounted end suction pumps feature an improved bearing frame design with sealed-for-life bearings that meet all industry requirements for a minimum L 10 life of 60,000 hours. The improved design also incorporates a unique sealing system which prevents the migration of water into the bearing frame.
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, will highlight its latest commercial offerings at the Mechanical...
Rinnai’s RCW Series commercial boilers are delivering sustained, high efficiency water heating performance at 2150 Condos in Toronto, marking the first installation of th...
