This document contains the complete illustrated instructions for installing the Hercules Steam and Hot Water Heating System, a boiler manufactured by Sears, Roebuck and C...
Trane Mercury Seal Ad (1901)
This document contain an ad from Domestic Engineering (circa 1901) featuring the Trane Mercury Seal which was attached to an old steam heating system or to an old vapor plant of any type. The mercury seal was used to create vacuum within the heating system.
Comments by Vanilla
Sears, Roebuck, and Co. Hercules Boiler Manual (1937)
HB Smith Series M40L Mills Water-Tube Boiler (1980)
This document contains the manufacturer's instructions for the HB Smith Series M450L Mills Water-Tube Boiler for automatic firing with oil or gas (Steam, Vapor, or Water ...
HB Smith Series 45 Mills Boiler Jacket Assembly Instructions (1979)
This document contains the jacket assembly instructions for the HB Smith Series 45 Mills Boiler (circa 1979).
